Ek k swap fuel rail
Old Feb 11, 2023 | 08:19 PM
Brokenfitting's Avatar
Default Ek k swap fuel rail
Hey I have a k20z3 I heard somewhere you can use stock fuel rail so I got the fittings and realized that there’s no return line. Do I need it? Can I just plug the ek return like?
Old Feb 12, 2023 | 03:04 PM
Default Re: Ek k swap fuel rail
Bump
Old Feb 12, 2023 | 03:21 PM
Ryanthegreat1's Avatar
You can use the stock K fuel rail as a dead head system. However the EK doesn't have a fuel pressure regulator in tank so you would put a fuel pressure regulator on the firewall. Then dead head the fuel rail off the regulator and return off the regulator to tank.
Or buy an aftermarket fuel rail with a return but you will still need a fuel pressure regulator.
Old Feb 12, 2023 | 04:06 PM
sorry I’m alittle confused so I’d have to put a regulator between filter and rail but how would I get a return line. From the regulator?
Old Feb 12, 2023 | 04:35 PM
Yeah so the regulator has to send fuel back to tank to release pressure to regulate it.
Then the fuel rail dead heads off the regulated fuel pressure port off the regulator.
There's probably a diagram of this.
Old Feb 12, 2023 | 08:59 PM
dope thanks dude
Old Feb 12, 2023 | 09:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You MUST use a stock fuel rail if you run a fuel system like the diagram above. This is the only way you will get a reasonable distribution of the fuel to each fuel injector.
EkTypeRace
Aug 18, 2022 07:52 PM
Knuckles91
Oct 5, 2011 08:34 AM
vick2121
Jan 26, 2009 10:39 PM
speedooo
Dec 18, 2007 10:49 AM
trillion$
Aug 2, 2004 02:03 PM
