Honda Civic B18C1
Hoping I can find some direction with this. My Civic will start and run for about 4-5 mins then will turn right off. Very frustrating. I’ve replaced main relay/fuel pump. But no change. I can see my A/f ratio is high (lean) any good advice??
Do you lose electrical power ? If you installed a factory OEM relay and 100% sure it's good did you check the ignition switch? Does your car have a kill switch or an alarm?
If you don't lose electrical power check your fuel pressure. You can should maintain fuel pressure for a little bit when you shut off the engine.
reggiec9
Nov 3, 2018 08:52 AM
berlido1208
Honda Civic (2001 - 2005)
Apr 10, 2013 11:08 PM
young geezer
Jun 29, 2009 09:53 PM
