1995 Civic ex <f20b swapped > need help with dizzy
Old Jan 29, 2023 | 12:26 PM
Evolov3's Avatar
Default 1995 Civic ex <f20b swapped > need help with dizzy
So I recently have swapped my 95 civic 2dr 5spd, with a f20b dohc after a good hone, new gapped rings, front and rear main seals, new rod bearings and main bearings, thrust washers, a light polish to clean crank, the motor is stock up to I ported the head and intake manifold, took out the it's has new belts and water pump, head gasket. That's most of background so I used a 93 civic dx engine harness spliced to a prelude harness all obd1 to run the engine not to hard extend some wires and wire in new injectors I have a chipped P06 with rdx injectors and I'm running a h22a base map tune with the rdx injectors settings set on hts. Anyways I'm at the point were I wanted to crank the motor over just to here it start, well it cranks good 👍, but I'm not getting spark at the dizzy I tested the injectors and they pulse then test light while cranking, I test all dizzy wires for continuity all were good. I have checked each sensor wire from the dizzy to the ecu make sure they have no breaks or shorts to grounds. I have ran the icm test on every wire, test the spark test at coil after switching about 3 igniters and coils I had one that was showing a spark when turned the key to off position it would send a spark to the test light. I don't kno wht that means I have tried everything I have seen on YouTube and have read about. I'm at a loss I am waiting on a new dizzy thus week but I feel like it still won't spark cause swapped and rebuilt my dizzy like 3 times we 3 different dizzys I know atleast o e of them was a working dizzy previously. I'm just searching for any tech input on maybe something I haven't thought of or have overlooked. Thxs for anyone who helps.
Old Jan 29, 2023 | 06:20 PM
Eye h8 hondas's Avatar
Default Re: 1995 Civic ex <f20b swapped > need help with dizzy
Silly question, but is your CPS plugged in, or checked for being good??
Old Jan 29, 2023 | 10:08 PM
Evolov3's Avatar
if you mean my crank position sensor it's obd 1 so it's wired into the dizzy and yes i checked all the sensor wires inside the dizzy for continuity all 👍 good
estefi357
Apr 29, 2016 08:29 PM
Eric Graham
43
Mar 12, 2014 07:28 PM
Reefsdaddy
52
Feb 23, 2014 10:13 PM
Creator
Nov 15, 2012 07:43 PM
blu1840
Jan 10, 2009 11:10 PM
