Suspension & Brakes Theory, alignment, spring rates....
Best way to add static caster on EG/DC2 chassis?
Old Jan 29, 2023 | 09:05 AM
kmvguy83's Avatar
Loved
Icon5 Best way to add static caster on EG/DC2 chassis?
I recently completed the Prius EPAS swap on my EG, and I'm trying to add some static caster to gain some Return to Center and add more stability to my car.
My preference is the hardened rubber bushings and want stay away from spherical or poly urethane bushings due to the reliability.
Also, I'm not too worried about steering wheel effort nor the bump steer since both of those are remediated with the Prius steering column setup.
I want to aim for around 4-5 degrees of positive caster to my car.
I'm aware there is no way to adjust caster on these chassis from factory but I've seen some aftermarket parts that adds positive caster.
This car will see mostly street time, with occasional AX/HPDE events.
Does any one have experience on any of these setups and would like to recommend?
Couple of options I saw are.
1. Truhart: Front Camber / Caster Kit CAMBER: +2°~-2°/ CASTER: +2°~-2°
This one is the UCA replacement. Seems to add about 2 degrees of caster max.
There are multiple companies that has the same part. From my research Megan, Truhart, Hardrace are all made from the same factory and only difference is the branding itself.
2. Whiteline: Front Control arm - lower inner front bolts
This is the classic shimming the LCA method. Cheap method of adding up to 2.5 degree of static caster.
The kit is cheap but looking at the picture I can probably replace the kit with some high grade washers instead...
3. PCI: ALUMINUM FRONT LOWER SPHERICAL CONTROL ARMS (92-95 Civic/94-01 Integra)
Lower control arm replacement and about 2 degree of static caster. Thank to @Pepe14 , I learned that this part exist.
I'm aware of how capable spherical bushings are for race car application but my biggest worries on these units are the reliability.
Suspension noise I can live with because my STR prepped S2000 has couple of spherical bushings (top hats, front and rear sway bar end links) but the issue is the reliability of these parts.
I rarely put any street miles on my S and I had a pair of bushings that completely seized and broke off.
4. Offset LCA poly bushings. (No links)
I rather not do this because, offset poly bushings will probably be the noisiest and least reliable part out of all the options here...
But if anybody have experience or input on this, please let me know.
Old Jan 30, 2023 | 04:52 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Best way to add static caster on EG/DC2 chassis?
Define 'best'.
Cheapest/easiest would be the Whiteline kit. It's adjustable too.
The PCI lowers add caster and address a couple of other geometry issues. They are pricey, but high quality.
The upper arm seems like the obvious answer. I don't have a terribly high opinion of the Truhart stuff, but I've never used it either.
Honed makes a set of super trick upper arms that are the best design available, the additional caster is fixed at +1* on them though, and they are pricey.
On EG/DC chassis folks have been known to swap UCAs left to right and gain a couple of degrees. This is free and arguably worth a try.
Probably a combo of parts is the way to go. Like maybe the Honed arms plus the Whiteline kit to allow some adjustability. Keep in mind that adding caster tilts the steering arm down and affects your bump steer curve as well. I imagine you are aware of this if you are already driving a track-prepped S2k.
There is an upper limit on how much caster you want to run with EPS before the increased load starts failing your EPS motor, especially when combined with race tires and/or aero. I'm up against this issue at work right now and it's a race ender for obvious reasons.
Old Jan 30, 2023 | 07:41 PM
kmvguy83's Avatar
Loved
Originally Posted by spAdam
Define 'best'.
Thanks for the informative reply!
I suppose the term "best" is relative. haha
My definition was getting the setup that suits the car usage. Street-able setup with occasional AX/HPDE events.
Honed UCAs look amazing. And just like you said, combining this with the whiteline kit might be the best way to go about the static caster goal.
Have you ran into anybody using Kingpin Machine: "DC Integra/EG Civic Complete Front LCA Caster Offset Spacer Set"?
Seems like this kit not only spaces out the LCA but also offsets the compliance bearing and shock mounts too.
Also, can you elaborate on your EPS issues you are experiencing? I would love to hear more on this.
Old Jan 31, 2023 | 08:08 AM
spAdam's Avatar
Loved
Community Favorite
The Kingpin misalignment spacers are for use with their spherical bearing lower arms. Chris @ Kingpin really knows what he's doing and is passionate about it. Good stuff there.
Can't really elaborate on too much on EPS issues because I'm still investigating... but high caster could be a contributing factor. It's common knowledge that high caster angle increases steering effort, and since you're asking your EPS to deal with that extra effort, it follows that at some point you'll find the limits of what the motor unit can handle.
Old May 17, 2023 | 06:43 PM
mattkosem's Avatar
What did you end up doing? I ended up grabbing the PCI setup (compliance bushing and arm) for my EG. I'll put em in sometime in June most likely.
I initially wanted the Hardrace arms (same as the Truhart but blue) but Hardrace discontinued them. I asked why, and they told me customers had issues with them.
In my searches, I've encountered multiple people citing issues with the hardware on the whiteline kit. Hardrace does sell a similar kit, though, FWIW.
Old Aug 17, 2023 | 05:02 AM
mattkosem's Avatar
BTW, I had a bunch of noise develop in the first month/1k miles with the PCI arms and had to pull them.
Considering upper arms and the Hardrace caster kit (hopefully better hardware than the Whiteline one) to get the caster back because it did make a positive impact.
--Matt
Old Aug 17, 2023 | 10:44 AM
spAdam's Avatar
Loved
Community Favorite
That's unfortunate. Do you know where the noise was coming from? Was it the uniball?
FWIW, the Truhart arms are either coming out of the same factory or they are just straight knockoffs of the Hardrace stuff. I think it's more likely the former. I don't have a lot of faith in the balljoints of either (but I haven't used either because of this). I think the Honed arms are going to become the de facto adjustable upper arm as more people discover them. They're expensive, but all of the shortcomings of other aftermarket arms look like they're well addressed - and they use an oem style ball joint.
Old Aug 17, 2023 | 11:46 AM
mattkosem's Avatar
Haven't had a chance to diagnose yet. Have a track day I needed to get the car sorted for so back to safe rubber for now. 🤣
Megan, Truhart, Hardrace, and some K-Tuned parts all come off the same line. It is my understanding they are mostly identical apart from color.
Does Honed make an EG adjustable arm? I thought they only make an EK part.
Old Aug 18, 2023 | 06:44 AM
spAdam's Avatar
Loved
Community Favorite
Yes, the EG/DC ones came out first actually.
Old Aug 18, 2023 | 07:28 AM
mattkosem's Avatar
Oh, I see now that the specs say 1 degree. I missed that initially. That's not a lot TBQH.
There are several more options for EKs that don't have EG equivalents, which is a bummer. Neither PCI nor SPC make their variants with caster for the EG. 😔
Some folks swap the uppers from left to right for positive caster, too, but it seems like that route tends to increase it too much and causes problems.
Old Aug 18, 2023 | 09:55 AM
spAdam's Avatar
Loved
Community Favorite
Really? It's always seemed the other way around to me, which surprises me due to the higher parts count of an EG/DC arm (because of the separate pivots) but makes sense because it arguably covers more cars.
Didn't realize the Honed arms only get +1° on EG/DC application. Is anyone doing an inner pivot set that allows you to shim the arm back?
I seem to remember that swapping the arms left to right caused more problems than it was worth. Tower clearance, failed ball joints, can't remember the failure mode.
Old Aug 18, 2023 | 12:35 PM
mattkosem's Avatar
None I can find unfortunately. I'd love it if there was an option that even just had a fixed +2. I don't need the adjustment, honestly.
Probably will just end up trying the Hardrace shim kit since apparently the hardware on the Whiteline kit is not trustworthy and breaks.
--Matt
Old Jun 20, 2024 | 06:03 AM
kmvguy83's Avatar
Loved
Bringing this from the dead.
I actually just got the whiteline hardware installed at ~1.9 caster increase.
I haven't put any miles on this yet but I'll update here if something happens.
Old Jun 20, 2024 | 09:42 AM
spAdam's Avatar
Loved
Community Favorite
Hoping to have an update for myself soon. Ended up ordering a set of the Hardrace front compliance bushings for my upcoming DC subframe swap. Ordered them back in April, they told me end of May now end of June for production. Will be doing them with Honed geo kit (ball joints/steering rods/rear RC correction). I might regret the spherical version since I still 'daily' the car, but it should be a fun setup if it works as planned.
Hardrace Hardrace Front Compliane Bushings (Pillow Ball) Offset/Increase Caster 2pcs/set for 92-95 Civic | 94-01 Integra – Velocity Shop (hardraceusa.com)
Old Jun 20, 2024 | 12:07 PM
kmvguy83's Avatar
Loved
do they make the rubber mount version of this by any chance?
This is my current with whiteline 1.9 degree worth of spacers/shimming.
Old Jun 20, 2024 | 01:34 PM
spAdam's Avatar
Loved
Community Favorite
They do list a rubber version. Hardrace Hardrace Front Compliance Bushings with Offset Bushings Increase Caster - 92-95 Civic | 94-01 Integra – Velocity Shop (hardraceusa.com)
Old Oct 22, 2024 | 07:13 AM
spAdam's Avatar
Loved
Community Favorite
Four months later…
Old Apr 20, 2025 | 10:29 PM
kristo's Avatar
Loved
Icon4 Re: Best way to add static caster on EG/DC2 chassis?
Hardrace front compliance bushings for ... DC
I suppose this works by pushing the rear of the arm outwards/sidewards. Doesn't this put (too much) twist stress on the front bushing? Does the arm even fit when using a spherical front?
Old Apr 21, 2025 | 08:41 AM
spAdam's Avatar
Loved
Community Favorite
You are correct. There's not much twist/deflection on the inner lca bushing. The longitudinal distance between the inner lca pivot and the compliance bearing is fairly short compared to the distance from the inner pivot to the lbj, so it only takes a little bit to affect the desired caster change.
About the best picture that I have:
Old Apr 21, 2025 | 12:04 PM
Casey's Avatar
Interested to see what you gain in caster with the compliance bushings. I recently ordered the shim/bolt caster kit from HR and they reached out to see if I was ok with an an eta of end of May. During that convo I asked how much caster the compliance bushings would give and was advised .5* so it seems insignificant by itself.
Old Apr 22, 2025 | 06:49 AM
spAdam's Avatar
Loved
Community Favorite
The added about .5. These cars don’t need a lot of caster like a Mac strut car does. I ended up
right around 2 degrees.
Old Apr 22, 2025 | 09:30 AM
Casey's Avatar
Good deal thanks. I was hoping to get 2-2.5* in mine for the same reason as the OP so the bolts and washers should suffice
Old Apr 22, 2025 | 10:46 AM
spAdam's Avatar
Loved
Community Favorite
It's a good mod and a little goes a long way. I'm not EPAS on this car but combined with swapping to the Integra subframe/rack, the steering has a real nice "modern" weight to it and does center nicely. Theoretically we can run a little less camber and get back some straightline traction when we run more caster too.
Old Apr 22, 2025 | 11:20 AM
Casey's Avatar
Pretty much what Im aiming for. I dont have EPAS either but run an integra pump and rack, ITR crank pulley and a 94-97 pump. Its extremely subtle and still heavy feeling while driving which I love but it absolutely noticeable when parking. Doesnt feel completely numb but I have absolutely no return to center which I look forward to
Old Aug 22, 2025 | 07:59 AM
Casey's Avatar
Update - Hardrace are still a bunch of clowns and continued to push the ETA out on their bolt/washer caster kit, but at least their CS rep used a sad face to show me she cared after the 3rd eta extension. I cancelled and ordered Whiteline and got them in 2 days, I dont see any reason why these were bashed previously. Will update once installed with my impressions
