Eg weird noise when slowly taking off
Old Jan 23, 2023 | 04:13 PM
Spaz253's Avatar
Default Eg weird noise when slowly taking off
Hey yall, my son's got a eg coupe b16a motor we noticed a weird noise. No noise doesn't start until after the car is warmed up but it only happens when you slowly take off like if you come to a stop and then go to take off you'll hear it for a couple seconds and then it's fine while you're driving. We just replaced the passenger side CV axle because the boot was ripped so we know it's not that.. I'm attaching this link so u can watch the video we recorded so u can hear the noise https://streamable.com/rk6yam
Thanks
Old Jan 23, 2023 | 04:26 PM
Spaz253's Avatar
Default Re: Eg weird noise when slowly taking off
if you can't click it just copy it into your browser it will take u to video
Old Jan 24, 2023 | 07:08 AM
Relic1's Avatar
to me it sounds like a bushing in the suspension.
Old Jan 24, 2023 | 02:16 PM
Spaz253's Avatar
could it be these ball joint ends ? Just noticed the boots r ripped
Old Jan 25, 2023 | 07:36 AM
Relic1's Avatar
yes.
that looks like it did not happen recently, they have been torn for a while... do not delay replacing them. When they fail they tend to fail catastrophically and very bad things can happen very quickly.
edit: the bolt to the right of it looks strange too (brake pin slider I believe) that entire pin to the bolt should be covered by the rubber boot to keep the grease from being washed away and rust from forming, the inner part of the seal looks pulled away from the part as well... this suggests that the slider pin may be frozen and not sliding correctly as the pad wears. The bolt doesn't look tight either... then again maybe it's just the angle/lighting and my bad memory.
Old Jan 25, 2023 | 04:16 PM
Spaz253's Avatar
yes.
is there any way you can circle on the picture what bolt you're talking about?
Old Jan 26, 2023 | 01:17 PM
Relic1's Avatar
I don't have any photo editing SW other than paint on this computer or I'd have done a better job and resized it to fix the screen better.
Red is the bolt's head and bulk of the exposed pin, yellow is where the boot looks slipped off a bit.
lopezchris21
14
Aug 10, 2008 06:57 PM
driftahboi
Oct 25, 2007 06:11 PM
A is 4 PiMp
Sep 29, 2006 07:29 PM
BANNED_ID
12
Jul 20, 2005 12:23 PM
dopehatch
Jul 14, 2005 10:02 PM
