Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Car Intermittently Won't Start
Old Jan 16, 2023 | 05:04 AM
mmorris1's Avatar
Default Car Intermittently Won't Start
I have a 2012 Honda Civic LX coupe, manual transmission, 195,000 miles. For the last year or so, once in a while, the car won't start on the first try. When I turn the key I might hear a slight hum, or I might hear nothing. I turn the key off and try again, and it starts like nothing is wrong. Sometimes it takes a third try. It might happen once in a month; it might happen two days in a row. My mechanic says it's probably either the starter or, if I understood him correctly, something sticking in the clutch. He suggested I pump the clutch a couple of times when the key was on but that didn't work. He doesn't want to replace anything because it so seldom doesn't work that he hasn't experienced it. He doesn't charge if he installs the wrong part, so he basically wants to wait until the car is towed to him. I am single, live alone and have a long drive to work. The battery is new. I'd really like this repaired! Anyone have ideas as to what it might be?
Old Jan 18, 2023 | 06:26 PM
johnnybgood1's Avatar
Default Re: Car Intermittently Won't Start
If the engine simply doesn't turn it could just as easy be the starter contacts going bad.
Old Jan 18, 2023 | 07:11 PM
mmorris1's Avatar
Thanks. If the starter contacts are going bad, then is the starter going bad and needing replacement? If not, what does one do about the contacts? Could it be anything else that you can think of?
Martha
Old Jan 18, 2023 | 07:19 PM
Yes, you can just replace the starter.
Old Jan 19, 2023 | 02:18 PM
mmorris1's Avatar
My mechanic will have to replace the starter, and he won't do it because it never acts up when I'm at the shop. If the contacts are going bad can they be replaced without replacing the starter? Is it a cheaper job?
Old Jan 19, 2023 | 06:11 PM
Yes, it's doable for the average Joe. Probably some how-to vids on youtube.
Old Jan 19, 2023 | 06:23 PM
mmorris1's Avatar
Thanks, I'll look for the videos. I have many skills and abilities; however, auto mechanics is not one of them.
Martha
Old Jan 19, 2023 | 06:28 PM
av911's Avatar
I don't know how's the engine bay in the 9th gen, but it's a PITA for the 8th gens.
Frank1515
Jun 24, 2015 10:47 AM
willant
Aug 22, 2014 02:32 AM
preludedriva
Nov 16, 2006 12:18 AM
yellowmonkeyboy
Jul 10, 2005 08:55 AM
