Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2005 Pilot - 02 monitor will NOT reset 400+ Miles
Old Jan 13, 2023 | 09:26 AM
jackisme's Avatar
Default 2005 Pilot - 02 monitor will NOT reset 400+ Miles
Hi, Hoping for a little advise... 2005 Honda Pilot threw a 0420 code, used cat cleaner and seemed to work which is crazy lol The Catalyst monitor DID clear! :-) BUT the 02 Monitor will not complete? I used the spacers on B1- Downstream, I drove ALL advised drive cycles over and over again now 400+ miles and nothing... all monitors clear except 02's even the evap cleared... Any help would be awesome.. Should I try changing sensors? If bad though wouldn't it throw a 02 code? PLEASE HELP ? :-) Thanks
Old Jan 13, 2023 | 09:43 AM
Ryanthegreat1's Avatar
Default Re: 2005 Pilot - 02 monitor will NOT reset 400+ Miles
Remove the spacer and try again.
Old Jan 13, 2023 | 09:52 AM
jackisme's Avatar
hi I forgot to mention in the first post. I ran it at first without the spacer after using cat cleaner.. the cat cleaner seemed to work as the Catalyst monitor cleared but the O2 sensor monitor never did clear. I was told that was the easiest one to clear so I was scratching my head.... but then after about 200 miles it through a pending 420 code so I put the spacer in.. now Catalyst clears and stays clear but same thing O2 sensor monitor never has cleared... do you think O2 sensor could be bad? I was told that if it were it would throw a code..thanks very much
Old Jan 13, 2023 | 11:32 AM
I think your catalytic converter is bad and needs to be replaced. The spacer is probably the reason your o2 won't clear. Probably pending on a slow response because of the spacer.
adobospoon
Oct 30, 2005 01:11 AM
brian_nbmc
Mar 11, 2003 02:31 PM
