Coolant leaking from radiator cap. 98 dx
Old Jan 12, 2023 | 04:40 PM
Gonzalez206's Avatar
Icon5 Coolant leaking from radiator cap. 98 dx
Anyone know what might cause coolant to leak from the radiator cap, it will slowly seep out while the car is running. Basically my bro has been driving my car these last couple of weeks, he popped the hood and saw the coolant reservoir tank was almost empty (said he didn't notice any visible leaks then), he topped it off but filled it past he maximum line. Could this cause a leak? but now the coolant is between the min and max line and its still leaking? or could it just be a bad radiator cap or something else maybe?
Old Jan 14, 2023 | 01:32 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Coolant leaking from radiator cap. 98 dx
The cap is probably worn; try a new OEM radiator cap they are cheap!
Old Jan 16, 2023 | 03:11 AM
DaX's Avatar
DaX
Loved
Community Favorite
Overfilling the reservoir above the MAX line can cause it to overflow. During the normal operation of the engine heating up and cooling down, the engine needs the extra space above the MAX line to expand hot coolant into, which it then sucks back into the system once the engine cools down.
It could also be a bad cap. As stated, they are cheap - I would go ahead and replace it unless you know it's new already.
Old Jan 16, 2023 | 05:43 AM
BeaterD16's Avatar
Replace the cap. They are cheap from the dealership or HondaPartsNow.
ShadowDaisy82
11
Aug 7, 2015 10:34 PM
jackloconnor
Honda Civic (2001 - 2005)
Jun 2, 2015 01:55 PM
ALLMOTORD16Z6
May 20, 2005 03:27 AM
PatrickGSR94
Feb 24, 2003 12:27 PM
PatrickGSR94
Jan 24, 2003 08:26 AM
