92 del sol b20 swap , trying to wire up 😩😩
Hi I’m new here in this page, my project is a 92 Del Sol. I bought with out engine or transmission…I bought a 2000 CRV AWD with Manual transmission and stripped it completely…I literally have everything off the car except shell. So I have all wiring from the crv …..engine is mounted …now I’m stuck …my issue is how do I wire it up?
I started de-pinning and organizing what I think might work if I de-pin ….
thanks any help will be appreciated
Agree - you need to keep the harness that matches the chassis - much easier to do this way. Find a good used one in a junk yard or online. Or, there are aftermarket version from Rywire, Monotech, etc.
DO NOT 'throw away' the CR-V harness. It's plug & play for 99-00 Civic owners swapping in a B18/B20 and fairly valuable because of it.
Wouldn't a '99-01 Integra LS engine harness work pretty well ? I mean, if using a '96+ LS intake manifold (complete), this engine harness plugs into everything on the engine and it SHOULD plug into both shock towers in the Del Sol.
