Need help with an electrical problem
The door light on my gauge cluster (91 CRX Si) is always on. When the car is off, the light is off but the battery is getting drained. I think it has something to do with the seatbelt retractor continuing to be activated because it thinks the door is open (I noticed it was warm while I was doing something else in there, door open car off). Anyways, I only see 1 switch in the door jamb and found it only controls the dome light and the chime...unless there is something I'm missing. Also when I close the door the gauge light sort of flickers off but then comes back on, like I'm either jostling something inside the door or it's not closing properly. Any idea how to fix it ?
4DRmafia
10
May 29, 2004 07:46 PM
huntarrr
14
May 7, 2004 12:42 PM
