91 civic no crank
I have a 91 civic lx sedan that is B18 and auto to manual swapped. Issue I am having is it will not crank from key just clicks once but always cranks if starter is jumped. I Have changed with new the starter, battery, battery terminals and wires, and all bay grounds as well as ignition switch a which didn't work and lock cylinder was in bad shape so decided to change to the JDI plug and play push to start system and still no change any suggestions would be great thank you
Have you double checked the wiring of the park/neutral safety switch to see if it's still bypassed and those 2 thicker wires are jumped together? Checked fuses? Maybe a bad relay?
For park/neutral its the thick I believe black/white wires at the auto shifter location correct? May just go get a bunch of fuses and just replace them all just to be safe since they can appear good and be bad. What relays would all effect this?
OutlawboostedEF
Dec 13, 2014 11:41 PM
daviduhley
Feb 10, 2013 08:33 PM
