So, got to looking at my daughters Civic the other night and realized the left fender is significantly closer to the wheel/wheel clearance is off somehow. Need some advice on what might be the issue. Think she has some sort of aftermarket coils. Drivers fender with tight wheel clearance.
Those are lowering springs you cant adjust them
BUT YOU CAN USE A GRINDER lol
Mabe aftermarket camber arms should be next to top of the shock
Tire size prob different
As in grind them off to remove them?
not following the aftermarket camber arms - I don’t see anything that doesn’t look stock in that regard. I could be wrong.
Probly tire size/ rim size
one side of the ground is higher
Aftermarket camber arms look them up its the big U around the top of the shock and 1 tire will be more tilted then the other
But you can cut the spring down to lower the car probly not worth it
