Spark test with fuel pump fuse removed still work?
(96 Accord Value) I removed the fuel pump fuse to do a pressure test, then I decided to do a spark test, but get none. I was wondering if the fuse removal would prevent spark from occurring?
Thanks
Thanks
No, fuel pump fuse is for fuel pump only. Spark, you;d want to be looking at the main relay, ecu fuse or some other kind of electrical problem causing no spark (distributor, wiring, coil, control module, pcm, bad sensor)
wtfisvtec??
38
Jun 30, 2024 05:13 PM
BBuncky2
Sep 2, 2008 05:13 AM
