92 Eg best upgrades?
Hello everyone on HT, I was wondering what you guys would say the best parts to upgrade to improve handling. I have a budget so im looking to upgrade stuff that will help handling the most. the car is all stock besides coilovers and 15" rims (these came on the car when i bought it). I was thinking or getting front and rear sway bars, maybe a 3 point strut bar and strengthening the chassis, do you guys have any notes/suggestions from experience?
OEM or Energy for bushings
Check out Skunk2 and Blox for an affordable but decent quality brand
I'm going to second what everyone here has pretty much said....suspension refresh. I don't recommend Energy Suspension bushings unless it is a full race car or your like a harsher ride.
I recommend using Hardrace's rubber bushings instead. These are improved over OEM, but not as harsh as a poly bushing --> https://www.hardrace.com/Product_det...9&MainType=109
If you want a polyurethane bushing then Energy is the way to go --> https://teamenergysuspension.com/pro...ster-bushings/ (Note, I don't believe this kit comes with RTA bushings...may have to source those separate and chances are if you've never changed yours, they are shot).
Then after you do that, get a proper alignment.
Other things to consider to improve handling: steering rack refresh, tie rods, ball joints/UCAs, hubs and bearings....
Thank you guys both very much for the knowledge. I dont want a really harsh ride; the civic is already on coilovers that have 12K spring rate front, 6k in the rear (I forget brand name they were on the car when i got it) and the ride is super duper bumpy and stiff. I plan on either getting coilovers with 9.8K spring rate in the front and 5K in thr back or going back to the stock suspension or closer to it so I do not think ill go the poly bushings. I do want to improve my handling as much as I can without compromising on the comfortability to much, (I know ill have to compromise some tho obviously). Would you say all these parts youve listed would help more or equivalent to getting larger sway bars, adding strut bars, rigid collar kit, etc?
Charlie Moua
16
Feb 25, 2006 01:06 PM
pynikal
Feb 16, 2006 06:08 PM
