95 accord 2.2l ex F22b1 abs wont bleed
Hello guys I’m trying to bleed my abs module on my 95 accord, I back probed the abs pump wire an set up a test wire on my battery, when I touch the test wire to the pump wire it wines like it should, so as I manually pump it i then open the bleeder screw an get nothing no fluid or pressure just noise from the pump, I also have a code 1 abs on my dash. abs light always turns on after pump wines once started. I also have half a brake pedal meaning I think only the front brakes are engaging mostly. I bought a prop valve just in case because I don’t want another crappy abs module if needed. I also notice slight wetness around the module, around the lines connecting an revisor.
