B16 tucked engine harness
Old Dec 10, 2022 | 03:14 PM
Brokenfitting's Avatar
Default B16 tucked engine harness
Hey guys I just bought a tucked harness but I noticed it doesn’t have a vtec pressure switch plug but it has a vtec solenoid plug. So I just got ready to pin it in myself but noticed it has a cable in the pin already but no plug. Does anyone know what’s up. Since its a ticked harness did they make it somehow that I don’t need it?
Old Dec 10, 2022 | 03:18 PM
Chance EG's Avatar
Default Re: B16 tucked engine harness
Some people opt to not run the VTEC pressure switch, and just bypass it in their ECU (assuming they're on a chipped OEM ECU or a full aftermarket standalone). In my opinion, this is stupid, but whatever.
Where did you get this harness, or who made it?
Old Dec 10, 2022 | 03:31 PM
I got it from Amazon. I have a p28 a52 obd1 b18c1 block with a b16 pr3-3 head if that helps. Link to harness.
Avaleer OBD1 Tucked Budget Engine Harness Compatible with Hon-da B/D-Series Ci-vic Inte-gra B16 B18 D16 https://a.co/d/jh6Zztn
Old Dec 10, 2022 | 03:39 PM
also this is the pin out I’m following
and then this is the ecu with the cable in it
Old Dec 10, 2022 | 04:10 PM
Chance EG's Avatar
If you wanted to run the VTEC pressure switch (I'd recommend this, and it's mandatory if you have a stock ECU and want VTEC to work), then you could simply get a plug kit and solder it together yourself. Since the wire is already pinned into the harness, you'd just need to find the other end and connect together what's needed.
https://www.ebay.com/itm/15310226408...3ABFBMvJjJ659h
Without seeing exactly what you have in front of you I can't say exactly, but that's the route I'd go. Best of luck with the Amazon harness, hopefully it all plugs in correctly and works reliably.
Old Dec 11, 2022 | 10:15 AM
Is there anyway to find the other end with out cutting it open?
Old Dec 11, 2022 | 11:22 AM
Chance EG's Avatar
So you don't have the clip for the VTEC pressure switch, and you also can't find the other end of the D6 wire? If you don't see it coming out of the other end of the harness, it raises the question on if it'd even be worth trying to find it, since if it's cut too short you'd have to extend it to reach the VTEC solenoid anyway.
At this point I'd message the seller on Amazon and see what they say, hopefully something useful.
Old Jun 3, 2023 | 06:40 AM
azjared's Avatar
Did you ever get any answers on this? I’m in exact same boat
Old Jun 3, 2023 | 04:22 PM
the manufacturer ended up doing the pressure switch bypass. So it ran good for me. The seller didn’t know **** about it so I just and to trace the wires.
Old Feb 20, 2024 | 01:12 PM
Folda's Avatar
Hi, I got the same harness. I was wondering how did you connect it to the left side of the car. The 20 pin connector that js supposed to connect to internal fuse box? I saw some adapters but I have no clue..
Old Feb 20, 2024 | 01:37 PM
are you talking about the squareish plug on the driver side strut tower. Next to clutch master and brake booster?
Old Apr 23, 2024 | 02:52 AM
kellerspec05's Avatar
My Rywire harness came the same way. On hondata smanager you can just click a box to bypass it, so it is not needed. If you are running a stock ECU, I would just wire in a new connector.
beat ignition
Honda Civic (2001 - 2005)
Jan 5, 2019 09:13 AM
$MIKE$
Jun 12, 2014 02:04 PM
B16b-EJ8
10
Apr 3, 2007 03:22 PM
ifIexplode
Mar 14, 2007 10:01 AM
