96 Honda civic delsol
Old Nov 23, 2022 | 07:14 PM
AlexLee's Avatar
Default 96 Honda civic delsol
Hey guys I have a 96 Honda del sol z6 swapped car ran fine until I noticed the block was cracked so I swapped in another z6 and now it’s flooding out so bad it will hardly run I’ve changed injectors everything to do with the fuel I’ve changed throttle body tried different ecu have tried a different jumper harness being that it’s a obd2 harness running a obd1 ecu and dizzy I’ve cleaned all grounds can’t seem to figure out the issue can anyone help???
Old Nov 24, 2022 | 04:29 AM
Stock95delsol's Avatar
Default Re: 96 Honda civic delsol
I can't help you fix the problem BUT be careful about running your engine rich because it will destroy the oil film on your cylinder walls and ruin the rings. for testing you might want to add some 2stroke oil to your gasoline to give it some lubrication.
Old Nov 24, 2022 | 05:34 AM
AlexLee's Avatar
I’ve done that I’m just lost on trying to get this thing to run.
jlbarrios
14
Dec 27, 2011 04:55 PM
dmoore2920
12
Apr 6, 2011 07:15 PM
teggi
May 26, 2010 07:28 AM
dreman24
Aug 10, 2006 10:47 AM
kool168
Dec 18, 2003 05:45 PM
