Code 14
Old Nov 22, 2022 | 04:43 AM
Jwilson93's Avatar
Default Code 14
Is code 14 tps on a 1995 civic 1.5L 16Valve that's the code I have I put a new tps in and it still has a up and down idle and the cel is still on any help would be great. I also think I have a hung injector because I have a misfire after about 10 minutes of driving I can hear it lose a cylinder and lose some power then I can hear the spitting or sputtering in the exhaust aftermarket exhaust full system. Thanks
Old Nov 22, 2022 | 09:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Code 14
Code 14 is not a TPS code... it is an IACV (Idle Air Control Valve) which is found on the back of the intake manifold just behind the TPS. The misfire is another matter. Run a compression test to see if you have a low cylinder.
Mr.Death
Apr 30, 2010 05:51 PM
crusto2k3
Dec 1, 2008 02:14 PM
yz125rider21
12
Feb 12, 2007 04:49 PM
stocker2shocker91
Dec 13, 2006 04:17 PM
