99 Civic tuning
I picked up this 99 for 6 bills and refurbed the motor to be everyday driver - belts, alt, ac, timing belt, Wtrpmp plugs but... now got the bug- so I dropped it, CA, header , flowFX . I will turbo eventually but now I'm looking to buy another ECM and socket to chip and tune . CAN I socket and chip 37820-2e-A2 from EBay and tune it while saving just CA/header settings on the original?
If you're going to turbo it may as well get Hondata S300 installed in a ECU and have a N.A base map for your setup now put in, and when you want to turbo it you can even do the same and have a new base map sent for boost and go from there, if it's a reputable shop like Phearable.net: Honda & Acura Performance Solutions they will give you a real base map that will run great! even the boosted base maps are great! i drove over a year on my base map on boost! it ran perfect! they did 1 adjustment when i sent a data log and that was for idle and cold start Contact them, they will set you up with everything you need!
Thats not completely true, like I mentioned a good tuner shop can make a very safe base map! Phearable.net made a custom map that I drove on for over a year on boost! This is how they remote tune with data logs.
What I want to do - remove my 37820-2e-a2. Which has adjusted itself to my bolt-one (CA, Header/cat delete) Buy another 37820-2e-a2 and socket it for a tuning set up. What I'm hearing it's better to get the OBD1 adapter cables and socketed OBD1 and tune that . The question then becomes- which obd1 for my d16y7 Auto?
What you're describing isn't what I think most people would just call a "base tune". If you had them do a full remote tune, and sent data logs back and forth and make changes as needed, that's, as you said, a "remote tune".
I am not sure what you mean when you say "SAFC", but the AEM 30-4110 is a wide-band AF sensor and display gauge. It will show you the air/fuel ratio sampled in the exhaust stream during engine operation, but it does NOT change/alter the tune in your ECU.
