2000 Civic LX Auto to Manual swap Y7 Throttle Body
Old Nov 20, 2022 | 06:24 PM
HTautodc's Avatar
Default 2000 Civic LX Auto to Manual swap Y7 Throttle Body
Yet another thread for auto to manual swap. I have a 2000 Civic LX Auto and wanting to do the manual swap soon. Luserkid's writeup shows to change the intake manifold and throttle body into a Y8 but I would rather keep my Y7 intake mani if possible to reduce the cost
https://honda-tech.com/forums/honda-...4pics-1337459/
According to Majestic Honda, the IACV for the auto and manual are different part numbers:
https://www.hondaautomotiveparts.com...hrottle-body-1
auto IACV: 16022-P2E-A51
manual IACV: 16022-P2A-J01
The part numbers for the throttle body are different:
auto TB: 16400-P2E-A51
manual TB: 16400-P2E-A01
I have everything except the throttle body and it is not available anymore. I am not sure if the parts numbers of the TB are different because the IACV is packaged, which has a different part number. I cannot find documents (at least with my searching skills or lack thereof) stating that the TB for auto and manual are the same. Can anyone confirm? I have looked in eBay but I cannot find any listing that specifies that the TB came from manual Y7.
Old Nov 21, 2022 | 05:24 AM
hondamark35's Avatar
Default Re: 2000 Civic LX Auto to Manual swap Y7 Throttle Body
I am pretty sure that all Y7s have 3-pin IACVs. you would only NEED to change the manifold if you are using an ECU for something other than a manual Y7.
If I remember, I can check my FSM to see what it says about the IACV differences auto to manual. my guess is that it's not significant in this case.
Old Nov 21, 2022 | 08:52 PM
HTautodc's Avatar
I will be using a Y7 manual ECU. I know that both Y7 auto and manual IACV are 3-pin. My confusion arises with the TB if the Y7 auto TB is the same as the Y7 manual TB.
Old Nov 21, 2022 | 09:17 PM
HTautodc's Avatar
Also, the part number for the Y7 auto IM and Y8 manual IM are the same. 17100-P2F-A10
I think what you are saying only matters if i plan to replace my IM into a Y8 manual, which i dont plan to, to reduce the cost of the swap
Old Dec 2, 2022 | 03:15 AM
HTautodc's Avatar
Anyone?
Old Dec 2, 2022 | 09:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This is untrue... the EX Intake Manifold part number is 17100-P2P-A10. They are not similar at all...
I suspect you could use the auto T/B with little to no issue... and if not, go hunt a manual LX T/B from your local "pull-a-part" salvage yard and install it. Either will fit your auto I/M.
KROGERSON
Apr 22, 2020 02:04 PM
calvin924597
Jan 29, 2010 06:24 AM
Derek128
Feb 12, 2008 08:13 PM
alacard
Dec 25, 2006 11:30 PM
igo4bmx
Apr 8, 2004 08:04 AM
