mugen baffled oil pan.........found one cheap and mine is dented.....should i?
Old Nov 18, 2002 | 03:55 AM
ben_vtec's Avatar
New User
Default mugen baffled oil pan.........found one cheap and mine is dented.....should i?
someone in the uk is selling one brand new in the box for £120, says he paid over £280 for it. i dont know if that seems expensive or not, but uk prices are normally a lot higher.
if i ever got a b20 bottom end, would i still be able to use it (it is ITR sump going on ITR motor at the moment)
my sump is dented so badly i want to change it anyway, i dont even know how much an OEM one is..........all help, very much apreciated.
Old Nov 18, 2002 | 04:09 AM
ZygSpeed's Avatar
Default Re: mugen baffled oil pan.........found one cheap and mine is dented.....should i? (ben_vtec)
Yes, I'd definately get the baffled pan if it was relatively cheap!
Good insurance even at full price.
Don't know if it will then/also fit a B20 bottom end (doubt it).
Old Nov 18, 2002 | 05:09 AM
DutchITR1689's Avatar
It's very easy to weld it yourself, if you can get a stock one for even cheaper....
Old Nov 18, 2002 | 05:41 AM
Smitdog's Avatar
Default Re: mugen baffled oil pan.........found one cheap and mine is dented.....should i? (DutchITR1689)
Wish I could weld!
Old Nov 18, 2002 | 10:55 PM
AJ PwR's Avatar
Default Re: mugen baffled oil pan.........found one cheap and mine is dented.....should i? (Zygspeed)
I think you will need the B18C oil screen as well to make it work.
Old Nov 19, 2002 | 04:52 AM
benmasters's Avatar
Default Re: mugen baffled oil pan.........found one cheap and mine is dented.....should i? (AJ PwR)
What is this? can you tell me please as i maybe buying a mugen baffled sump too.
Old Nov 20, 2002 | 03:32 PM
Paste's Avatar
Loved
Default Re: mugen baffled oil pan.........found one cheap and mine is dented.....should i? (George Knighton)
I would keep your stock block in the first place
Old Nov 20, 2002 | 03:35 PM
Reid's Avatar
Global Moderator
Default Re: mugen baffled oil pan.........found one cheap and mine is dented.....should i? (paste)
Being that you have no idea what setup he has in mind, why comment on it?
perpetualburn
Mar 14, 2008 03:28 PM
loudassVTEC
Nov 5, 2005 06:01 PM
RRRex
Nov 4, 2005 06:23 PM
jg
Jul 17, 2002 03:49 PM
Black R
Jun 18, 2002 05:56 PM
