Electrical issues or what?
Wassup I’m new to the site and I’m obviously missing something but just can’t see it for some reason. My 98 prelude base with some mods , and everything I’m mentioning is new. The alternator isn’t charging the battery, transmission is wanting to stall and won’t shift. Changed the ecu and fuse box cause of the Eld even tried the bypass on the Eld. With it installed the ground wire from the valve cover started melting and won’t crank with the Eld unplugged it cranks but still won’t charge transmission still acting up. Any thoughts or suggestions?
evilho75
May 13, 2012 01:35 PM
