Just picked up a new to me 94 civic hb
Old Nov 8, 2022 | 09:55 PM
skys.thelimit's Avatar
Default Just picked up a new to me 94 civic hb
Alright folks just picked up a new to me 94 civic hb
I just changed suspension which leads to my first question.
1.) oem struts removed but it also took the brake line mounting with it- do I need to fab a new bracket mounting location or is there one out there?
2.) do they make a rear upper strut bar (not seatbelt one) that does not have to destroy interior? I would like to just remove the suspension access panels only
3.) ok edit already - I have oem seats, delsol seats and ek seats- which sits lower to floorboard of the 3? I’m 6’1” could use the extra room. Figured I adk before swapping between all myself . If all the same does anyone from experience recommend a lowdown mounting bracket for the delsol seats to go in functionally?
thxs in advance
Old Nov 15, 2022 | 04:39 PM
Default Re: Just picked up a new to me 94 civic hb
No response? Any help?
Old Nov 15, 2022 | 08:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
1. You didn't name the brand of suspension that you purchased... so either fabricate a bracket for the brake line or buy a higher quality suspension system that has them integrated like stock struts.
2. I am not aware of one.
3. Neither the Del Sol seats nor the EK seats will bolt to the floor of your EG without modification... and the Del Sol seats will be dramatically different. They should sit the lowest if you can figure out how to make them work. Some would remove the seat pan/tracks/sliders from the EG civic seats and move them to the Del Sol seats.
Old Nov 16, 2022 | 03:59 AM
White_EG1's Avatar
Del sol seats should bolt up to eg but not ek
Old Nov 16, 2022 | 05:21 AM
pearl's Avatar
3 of the 4 seat bolts on the del sol seats will line up on the EK. do with that what you wish.
crzy619
Apr 17, 2011 09:35 PM
teknics1
Jul 25, 2006 12:07 PM
nickolas388
Oct 11, 2005 07:01 PM
nickolas388
Suspension & Brakes
Oct 10, 2005 05:14 PM
