shifter rod wobbly
Old Nov 5, 2022 | 06:21 PM
blackdog48's Avatar
Default shifter rod wobbly
Hi,
I was under my car and noticed that the shifter rod has a lot of jiggle in it. Is this a clear sign that something in the rod assembly is bad or can it be something else? Is it usually just the bushings that need replaced? Also, does this looseness tend to result in loss of transmission fluid? Thank you,
blackdog48
Old Nov 5, 2022 | 06:41 PM
standard235's Avatar
Default Re: shifter rod wobbly
https://honda-tech.com/forums/honda-...fvL0MeEaA7hRK4
Old Nov 7, 2022 | 03:51 PM
blackdog48's Avatar
Thank you standard235. It seems that my shifter rod (#12) is bad. The extension rod (#14) is solid at both ends. Can the bushings at the front end of the shifter rod be changed? I do not see part numbers for them, so I am guessing not? If not, can the shifter rod be purchased separately? I am only seeing the entire linkage for sale online. Cheers,
blackdog48
Extreez
Dec 8, 2006 06:08 AM
rls669
18
Nov 1, 2005 10:43 AM
iown2
Nov 29, 2003 08:53 PM
al3e
Jul 31, 2003 12:11 PM
Digital-R
Aug 24, 2001 09:55 AM
