Asking for suggestions on what I can do to fix this issue. I've research all over and done all I can think of to fix this problem. I've replaced the bulbs, bought a new part, and even change the connector plug. When I tested the voltage on this light, I get the normal 12v and the light works. But once I close the door and open it again the voltage goes to 1.5v and the light won't turn on. I can't get the voltage back up to 12. I took the panel off and check all the wiring behind it to make sure nothing is broken or loose. Is there a switch I dont know somewhere on the door?
any suggestion would help me. Thank you
