high pressure power steering bolt
Old Oct 5, 2022 | 03:21 PM
CheekySquid's Avatar
Default high pressure power steering bolt
Does anyone know what the part number of the 2 bolts that hold down the high pressure power steering line to the pump are? (or an equivalent bolt with the same threads/pitch)
Old Oct 5, 2022 | 09:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: high pressure power steering bolt
What year and model application do you have ?
Old Oct 6, 2022 | 05:01 AM
1996 civic reinstalling power steering for a gsr swap. I'm using a 98+ gsr pump with the bigger outlet and using the stock high pressure line that came with the car but I've lost the bolts that connect the line to the pump itself.
Old Oct 6, 2022 | 10:05 AM
spAdam's Avatar
Loved
Community Favorite
The parts catalog knows all
JIS small-head flanged is what you want if you want it to match original. Should look like so:
JIS Flange Bolt 10.9 Coarse M6X1.0 / 10mm Wrench - BelMetric
kuelerz
Sep 24, 2002 10:16 AM
