I am Stumped.... Crank no Start
Old Oct 5, 2022 | 08:30 AM
lee303's Avatar
Icon4 I am Stumped.... Crank no Start
I have a 95 Civic Dx Coupe manual. I got this car from my dad and havent been able to get it started. Crank not start issue.
I have change the Distributor
New Starter
New Ignition System
New Main Relay
New battery
New Spark Plugs and wire
Put it in time
Compression is good
Checked and replaced fuses
Still all it does is crank hard and just wont kick over. I hear the fuel pump prime. All lights on the dash comes on including the beeping when you put the key in. Non of the center info works though( AC, Radio)
Im stuck. My dad said the previous owner had a kill switch on it which he tapped into the ignition with but i had all that replaced anyway so not sure if its still a factor. I have a video with it cranking I just stuck any help would be more than apprecitated.
Old Oct 5, 2022 | 10:18 AM
Sic_DA_Nine's Avatar
Default Re: I am Stumped.... Crank no Start
use some tb cleaner and see if it starts. if it does, then you have confirmed that it is fuel related.
have you checked for spark?
Old Oct 5, 2022 | 10:22 AM
lee303's Avatar
yeah I sprayed some in there still no start. Checking for spark today I got the wrong spark plug tester so I gotta go back and get another
Old Oct 5, 2022 | 11:39 AM
Boxbox's Avatar
I know you said you checked fuses, but did you confirm they have voltage?
they have test pins at the top, test both sides
test all the fuses, it's so simple.
Old Oct 10, 2022 | 12:42 PM
lee303's Avatar
Checked all that and good and still same issues
Old Oct 10, 2022 | 01:10 PM
Boxbox's Avatar
confirm you are getting voltage to the dizzy?
Old Oct 10, 2022 | 01:11 PM
lee303's Avatar
How do I check that?
Old Oct 10, 2022 | 01:49 PM
DiogoLoureiroPT's Avatar
Check those 2 videos from chrisfix and see if they help you
Old Oct 11, 2022 | 05:33 AM
BeaterD16's Avatar
What do you mean by "ignition system"? Which parts did you replace?
Old Oct 11, 2022 | 06:13 PM
Sam_ej1's Avatar
Im having similar issue, let me know if you find the issue plz
Old Oct 12, 2022 | 03:55 PM
98civdx's Avatar
Master Detailer
you say you hear the pump priming. Have you verified fuel/ fuel pressure at the rail?
Old Oct 12, 2022 | 04:57 PM
lee303's Avatar
Sorry I wasnt getting emails. New development. I bypassed my clutch saftey switch with a paper clip to run some more test.( got tired of reaching under there and hitting the button) When I went to crank it she fired right up. Ran for 15min I turned it off to try and restart it before I took it for a test drive and now nothing back to the same issue crank no start. But not my dome lights are on and my lights behind my dash and my ac lights(still no radio) but I sprayed a little starter fluid in the throttle body and she did a little hiccup while cranking but wouldnt kick over. Now when I crank it and stop its got like a gulp sound when its done cranking. Tried to explain it the best i could.
Old Oct 12, 2022 | 04:58 PM
lee303's Avatar
I got a whole knew ignition with keys.
Old Oct 12, 2022 | 04:59 PM
lee303's Avatar
I have not verified that yet. I will tomorrow after work though
Old Oct 13, 2022 | 11:22 AM
lee303's Avatar
Update, Sprayed a lot of starter fluid in it and it fired up again so pretty certain its the fuel pump? But i hear it prime and I installed a new relay so not really sure?
Old Oct 13, 2022 | 06:40 PM
Sam_ej1's Avatar
Fuel pressure regulator, fuel filter, fuel injectors. there are youtube videos on how to check all of them.
Old Oct 15, 2022 | 11:17 AM
98civdx's Avatar
Master Detailer
Just because the pump primes, doesn't mean it's getting fuel. Verify fuel pressure at the rail.
If it has pressure at the rail, check voltage at the injectors.
it could be as stupid as a clogged filter, line, ect. Stop throwing money at it.
Old Oct 19, 2022 | 08:54 AM
lee303's Avatar
Can I use the D-Series fuel rail and fuel pressure regulator from my 99 civic ex on my 95 Dx?
Old Oct 19, 2022 | 09:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Nope.
Rappaface
25
Oct 13, 2022 09:34 PM
TheWhiteEF
May 9, 2013 06:08 AM
mynameizstitch
Mar 17, 2012 10:55 AM
eskimo10
Apr 25, 2007 08:12 PM
dplatt
Dec 15, 2005 11:21 AM
