1992 Civic EX D16Z6 No Start
Old Oct 3, 2022 | 02:36 PM
BeaterD16's Avatar
Default 1992 Civic EX D16Z6 No Start
SOLVED: Old battery could not handle load of starting the vehicle. I have never experienced a dead battery that acted like the one in this car. New OEM battery and the car fired right up.
I apologize for the extreme noob post but life has been extremely busy.
TL;DR
  • Replaced catback exhaust system, went to check for leaks
  • Would crank/not start, diag’d no-spark condition
  • Replaced ignitor and coil
  • Car cranks and sounds like it is “dying” Crank gets weaker and weaker even with battery charger hooked up
  • Checked trans/chassis and thermostat grounds
  • Battery has 12.2V while hooked up to battery tender and is date coded 2017
  • Hear rapid clicks from dash when car starts cranking, then clicks subside
Old Oct 3, 2022 | 02:39 PM
Boxbox's Avatar
Default Re: 1992 Civic EX D16Z6 No Start
Make sure your main relay is working, check your fuses.
does your fuel pump prime when ON(II)?
do you see a check engine light when the key is ON(II)?
Does the light come on and go away?
btw start with the SIMPLE, actually take your battery to get load tested.
Old Oct 3, 2022 | 02:44 PM
BeaterD16's Avatar
Site won’t let me upload videos from mobile. My apologies.
Main relay is good, fuel pump primes, CEL turns on and off as usual. Cluster lights get extremely dim during cranking. I will pull the battery and go get it properly tested. Again, apologize for the noob post. Just super busy and don’t have a bunch of time to do my usual diag.
Old Oct 3, 2022 | 02:46 PM
Boxbox's Avatar
Main relay is good, fuel pump primes, CEL turns on and off as usual. I will pull the battery and go get it properly tested. Again, apologize for the noob post. Just super busy and don’t have a bunch of time to do my usual diag.
best idea, sounds like a bad battery to me. Sometimes they can have voltage but weak current.
S!K TEG
Oct 16, 2014 04:59 AM
DIZSTRICTxB3A5T
Mar 11, 2011 12:41 PM
amej8
Honda Civic (2006 - 2015)
25
Feb 10, 2011 06:31 PM
pliskin679
13
Aug 3, 2007 09:30 PM
mikehawkBUiLT
24
May 15, 2004 05:36 PM
