2012 Civic Si Top Alternator bolt broke, HELP PLZ
Old Sep 27, 2022 | 03:01 PM
gh0st86's Avatar
Default 2012 Civic Si Top Alternator bolt broke, HELP PLZ
Was cracking the top alternator bolt loose and the end of the bolt broke off inside, what part of water pump assembly do I need and can I just remove that cover and replace it or do I need an entire assembly?
Old Sep 27, 2022 | 08:25 PM
Ryanthegreat1's Avatar
Default Re: 2012 Civic Si Top Alternator bolt broke, HELP PLZ
That is not part of the block but a water housing that bolts to the front of the block. You could remove it to make fixing that easier or replace it.
https://www.hondapartsnow.com/genuin...0-rez-a00.html
Don't forget the couple of gaskets that seal it to the block and water pump.
Old Sep 28, 2022 | 09:25 AM
gh0st86's Avatar
Yea I figured that out, I guess while I’m replacing that water passage/manifold, I’ll replace serpentine belt, idler pulleys, water pump, and tensioner while I have all that taken apart, really didn’t want to tear it all down again, but it’s all good. Any recommendations on alternators that work with civic si 9th gen, seems like the OEM DENSO is somewhere around $7-800, I could have a HO alt built for $400, trying to figure out everything I need to do while I’m in there. THX man!!!
fslim
Aug 6, 2015 06:18 PM
CRXB5
12
Jul 8, 2010 07:15 PM
smmcla
Mar 30, 2010 06:04 PM
sixgunsound
Jun 5, 2009 11:06 AM
joevincett
10
Aug 11, 2008 06:24 AM
