B20z swap into o1 teggy
Old Sep 21, 2022 | 11:55 PM
j.lane89's Avatar
Default B20z swap into o1 teggy
So I got a clean automatic tegg shell from my buddy.
Had a b20z with the awd trans and transfer case in my Ek.
Im in the middle of swapping the b20 into the teg now. The engine harness does not plug up on neither sides. Any recommendations? Or best solution?
B20ecu plug
Driver side
Driver side engine and chassis
Chassis
Ecub20
Chassis
Old Sep 22, 2022 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20z swap into o1 teggy
You need an engine harness from a '96-98 Integra LS (auto or manual depending on which you need)... the EK or CRV engine harness doesn't plug in.
Old Sep 23, 2022 | 01:16 PM
j.lane89's Avatar
Would these jumper harness work?
Would these work?
Old Sep 24, 2022 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That would work for the Distributor IF you were using a '94-95 Integra LS engine harness, but the '96-98 Integra engine harness that I suggested above already has the proper distributor plug on it to match the early type distributor that comes with your B20. You may need to purchase a distributor adapter plug IF your distributor is the OBD-2B type... but you have only shown pictures of the chassis harness shock tower plugs above, so I am unsure of what parts you currently have on the engine.
j4s0n1337
Mar 24, 2011 10:11 PM
RA122324
227
Oct 27, 2005 01:21 PM
GetawayInMoscow
38
Aug 1, 2002 11:59 PM
benzcivic99
31
Jun 22, 2002 09:59 AM
