LS-vtec with vtec killer question
Old Sep 19, 2022 | 08:10 PM
Jim Hiscott's Avatar
Default LS-vtec with vtec killer question
I have a ls vtec and I'm putting vtec killer setup with the roller rockers. My question is the oil filter sandwich plate that routes to the head, I don't believe is required anymore with vtec killer setup. And what about the oil passage plug on the bottom of the head(headgasket side) that has a allen plug in it... should I leave that plug in or should I remove it with the sandwich plate?
Old Sep 19, 2022 | 09:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: LS-vtec with vtec killer question
You can remove the oil feed line for VTEC between the sandwich plate and the back of the head, but the restrictor is for the lubrication of the cam cap/towers and cam lobes in the VTEC head properly, and thus, needs to remain in the block.
Old Sep 19, 2022 | 11:49 PM
I agree with you. I just wasn't sure and looking for confirmation. I sincerely thank you for your reply.....Mikey
b18c1hatch1992
Feb 19, 2010 01:17 PM
HondaPartsHero
Jan 5, 2006 07:08 PM
Trooper
Nov 17, 2003 07:25 PM
tegmaniac
Apr 24, 2003 07:37 PM
type r 01-1063
May 30, 2002 09:38 AM
