Compression test reading 0-0-9-89?
Old Sep 18, 2022 | 05:09 PM
BeardedBeast's Avatar
Default Compression test reading 0-0-9-89?
New here and dont know much about cars but did a compression test on a 92 integra and the readings from the spark plug hole closest to the distributor going right was
0-0-9-89. What could be causing such low readings?
Old Sep 21, 2022 | 08:23 AM
Sic_DA_Nine's Avatar
Default Re: Compression test reading 0-0-9-89?
if you do not know about cars, hire a professional.
does the car run? if it does, you probably did it incorrectly since it shouldnt with those numbers
Old Sep 26, 2022 | 04:29 PM
White_EG1's Avatar
Unplug the wires at the dizzy and take out the spark plugs and try again
76 camaro car
Apr 20, 2017 04:47 AM
Vladglad
20
Dec 18, 2013 02:56 PM
B18Redline
Dec 9, 2004 10:53 PM
F120man
Oct 20, 2002 03:30 PM
