2000 Civic EX Y7/Y8 Swap Questions
Recently I purchased a '00 Civic EX coupe with a spun bearing. Long story short, I rebuilt an old y7 block and put the y8 head from the coupe on it. It came with a P2P-A12 ECU but after the swap the engine will not run on the P2P. However, if I throw my P06 with a NepTune Z6 basemap in it, it will run but not great. Before the swap the P2P ran the car fine. Am I missing something? I noticed the Y7 block doesn't have a CKP but the Y8 does.
Would that be the cause? I appreciate any feedback on this.
The Y7 block DOES have the CKF sensor on the oil pump... the same as the Y8 block. This should NOT keep the engine from starting and running/idling... so you likely have other issues that need to be addressed. Your problem is NOT the ECU... either of them. Check your mechanical timing... and go back over your short block build. Also, check all of your wiring in the engine bay after the install... especially the thermostat ground and engine grounds.
Ek 2000
Jan 16, 2018 11:46 AM
Jayk00CivicEx
23
Mar 16, 2012 07:17 PM
