EK automatic has been sitting for 2 years... want to start it up
Old Sep 16, 2022 | 10:33 AM
fireant's Avatar
Icon5 EK automatic has been sitting for 2 years... want to start it up
My 2000 Civic has been in a garage for a couple of years and I want to start it up again.
So far I have drained all the fuel out and put a tsp of Marvel Mystery oil in each cylinder. If it was a manual, I'd put it in gear and turn the wheels to move things around some before I start it, but it's an automatic. Is there a way to exercise it a little before cranking without tearing down too much? It's been a while. Thanks for reading.
Old Sep 16, 2022 | 01:31 PM
Chrisfrom1986's Avatar
Default Re: EK automatic has been sitting for 2 years... want to start it up
Just start the car. Oil down the cylinder was dumb.
Old Sep 16, 2022 | 04:13 PM
theYBLEGAL's Avatar
Loved
You can probably just start it.
I had an auto sit for 5 years. Did an oil change by removing the valve cover and pouring the fresh oil all over the cam and rockers. Reinstalled the valve cover, checked the level, made sure new filter, fired right up.
Old Sep 16, 2022 | 06:44 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you want to turn the motor some before start to work that marvel around then you can turn the motor at the crank pulley with a 17mm socket and extensions on the driver side wheel well. Turn the motor counter clock wise.
Since you poured a little marvel into each cylinder, I would roll her outside before starting. You is gonna smoke for awhile burning off that oil out of the cylinders. If you do that in the garage you will smoke yourself out badly.
Since you already drained the fuel and put in fresh you shouldn't need a fuel injection cleaner. New fuel doesn't tend to gum them up like old fuel does.
Old Sep 17, 2022 | 07:35 AM
fireant's Avatar
Thanks yall. I gave it a try, but it wouldn't turn over. I loosened the out-going banjo bolt on the fuel filter and it didn't give me the impression there was much pressure in the system. So what can I check next? Maybe replace the fuel filter? It doesnt make the "prime" sound that I remember from before, so it might be the pump.
Old Sep 17, 2022 | 09:27 AM
fireant's Avatar
I found a local buyer who wants it as is. Thanks again.
ek9newbie
Sep 26, 2017 11:50 AM
Kure1121
16
Sep 13, 2011 07:55 PM
darkintegra
Apr 28, 2009 12:17 PM
DRcjvjcallday
Jun 10, 2007 07:14 PM
