type S oil pump on k20z3
Hello I need help. I'm trying to install an RSX type s oil pump on a k20z3. The factory chain seems to be too short. The sprocket is 5/16 larger on the type s pump. When I look up the chain, it seems to be the same for k20a2 as well as k20z3. What am I doing wrong here?
The part number of the chain that comes on the K20Z3 is 13441-PNA-004. The part that you will need to work with your A2 oil pump is 13441-PCX-004.
