B20 into a EK
Old Sep 4, 2022 | 07:37 PM
gylesyEK's Avatar
Default B20 into a EK
Hey everyone! i’m thinking of putting a b20 from an early crv into my Ek civic and have been told as long as i have the ecu, harness and everything to go with the b20 it will more or less drop in. is this true?
and also would i be able to put on a b18 vtech head on later and run it with the same ecu?
thanks heaps!
Old Sep 4, 2022 | 08:35 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20 into a EK
thanks heaps!
As long as your EK is a '96-98 model, it should work. However, there may be issues in integration this way... it is always better to use the engine harness that comes in your car and modify it to fit the engine. Also, the B20 intake manifold may not fit under your hood... replacing it with the '96-01 Integra LS/RS/GS intake manifold will make things work. This change reduces the effectiveness of the tune from the stock CRV ECU... and although the LS/RS/GS ECU (P74 or P75) will be slightly better, the tune is still not optimum. You cannot place a VTEC head on top later and the stock ECU still properly run the engine... it has no way of knowing that the cylinder head was changed and there is no optput for the VTEC solenoid.
civic_jason
Nov 15, 2012 07:44 PM
Ek4Daphatch
Engine Management and Tuning
26
May 11, 2012 11:28 PM
jeanhernandez
Dec 4, 2010 10:24 AM
Mushvroom
14
Jan 5, 2006 12:29 AM
h22dx
Feb 13, 2003 07:20 AM
