Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 honda civic ex
Old Aug 29, 2022 | 06:21 AM
Luis_23's Avatar
Default 2001 honda civic ex
My honda Temperature is below the middle but the coolant reservoir overflows and spill through the top. I can ihave the car running idling now problem but once starts driving for a few minutes start puking coolant.i put a new thermostat. You do here whining noise when driving could be water pump but no coolant coming from front of engine. Thanks
Old Aug 30, 2022 | 03:37 AM
benchwarmer's Avatar
5 Year Member
Default Re: 2001 honda civic ex
The radiator cap is supposed to hold some pressure ( 15 lbs. ? ) If it's worn then it'll go into the reservoir which has a pin hole and isn't supposed to hold any pressure , if the cap is good and thermostat is good and it still pukes when you drive it may be a blown head gasket .
Old Aug 30, 2022 | 03:59 AM
Luis_23's Avatar
I put new radiator cap and reservoir but used the old hose for it. Ill have to check the hose and do a coolant pressure test. Thanks for the help. I'll update you soon
Elviraa16
Jul 15, 2018 12:44 AM
anand47
Dec 21, 2017 09:19 PM
angelT34
Sep 5, 2017 09:02 PM
Steven Wicker
Feb 19, 2016 01:03 AM
