Hello, all! My son had the genius idea to replace his steering wheel in his 2013 Honda Accord with an aftermarket one. He didn't get too far, but far enough to remove the srs airbag from the wheel, and in doing so cut the wire to one of the connectors (rather than simply removing the connector!). I'm trying to put it all back. The only part I'm having a tough time with is the connector that has a red wire in it. The connector is surrounded by foam. I seem to be able to find other connectors to repair the wiring harness, but not this specific one. There's not enough wire left on the connector to splice to. Any thoughts as to what a part number is or source for this connector?
