JDM F18B Swap
Old Aug 20, 2022 | 05:06 PM
Lucidsounds's Avatar
Default JDM F18B Swap
Hey guys don't know how many people still come herebut I'd thought I post the swap I'm in progress with.
Old Aug 20, 2022 | 05:10 PM
Default Re: JDM F18B Swap
I have a 95 Del Sol. When i purchased it it had the d15b7 block and a different head from a 90' Civic.
Old Aug 20, 2022 | 05:18 PM
So far I have installed new coilovers from MaXpeedingrods in the front and have them for the rear but haven't put them in yet. I also have a control arm kit with camber adjustment. Made my own mandrel bent dual exhaust. I have 2 3" DMT mufflers that will be welded on. The whole beginning of this swap began because I popped the clutch from a stop... bad things happened and now the transmission grinds when in gear. So I purchased a F18B jdm Non vtec engine and tranny on ebay from jdm Tennessee for $1300. So now I get to figure out my cv axle problem as well as maybe a mount issue. I haven't gotten that far yet and will update as I go.
Old Aug 20, 2022 | 11:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That is an uncommon and unique swap. Good Luck.
Old Aug 21, 2022 | 05:10 AM
Yes it is as I have been searching for days for anything to do with this motor and the only thing I could find is that it comes out of a 94 Honda Accord Jdm CD3. But haven't seen a single video or post with real info other than it has 125 hp which is 25 more than what I had. And thank you. I'll need it lmao.
Old Aug 21, 2022 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It will basically be like doing a H22A swap... only without the power. If 125 HP is enough power for you... a D16Z6 makes that... and you can keep your A/C.
Old Aug 22, 2022 | 12:50 AM
Actually i never had A/C... The model i have came factory without it as well as no PS. The only reasons i chose the F18B were that it was cheapest and I love the F series. If I were able to I would have gotten the F22A6 with its transmission. Unfortunately it's my DD and I needed it done ASAP.
EDIT: The $1300 I spent includes engine and transmission.
Old Aug 22, 2022 | 09:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the reason that you bought this swap is because it was "Cheap"... don't forget that you will still need to BUY a set of mounts, custom axles, a midshaft, rear "T" bracket, shifter and shift linkage, and a large-necked half-width radiator with a slim line fan... not to mention a P28 ECU with a Hondata S300 for tuning inside. All of this list... will cost a significant amount of money.
Now, IF as you stated in the lower half of your last post above, that you chose this engine because you LOVE the "F" series engine family... not to mention being different in doing an uncommon swap... THEN DO IT MAN !!!
Old Aug 23, 2022 | 12:50 AM
I meant cheap as in I don't want to spend 5000 on just a motor. I have everything except the rear t bracket. And possibly the radiator. I read somewhere that the stock del sol radiator is good for a full H22. I just need the slim fan. As for tuning I'm using my P06 and added demon II with Neptune as software. The last step I have on that end is find the spot to add a resistor/jumper for the IAB.
Old Aug 23, 2022 | 07:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The P06 doesn't have the circuitry for the IAB's, so don't worry about them at all. Although it does give up a few lb/ft of Torque in the mid range, most people remove the vacuum box and connect the IAB vacuum disc directly to a vacuum nipple on the intake manifold so that the IAB's are "throttle controlled"... increasing air velocity while cruising making the engine more powerful in the mid range... and still opening things up for optimum WOT operation.
Old Aug 25, 2022 | 02:00 PM
As I working on the engine and prepping for install I found the swap mounts are not simply bolt on. The motor mount doesn't not line up and will need refabricated. The transmission mount needs holes opened up and a stud needs cut down to allow for bushing. Will post pictures as I complete these steps
Old Aug 27, 2022 | 01:48 PM
And the engine and tranny are in... kinda lol. It's held by two mounts so far. I still need to make the custom rear bracket. But atleast it's in. I'll post pictures tomorrow when I continue working on it
Dredakid05
Southeast (Sales)
May 13, 2011 09:43 AM
ef9robert
Oct 31, 2007 11:07 AM
no_one_
Dec 13, 2004 09:21 AM
