HELP!!! 1999 Accord won't start on first attempt just clicks?!??!!?
Old Aug 19, 2022 | 10:56 AM
t7o7m7m7y's Avatar
Icon4 HELP!!! 1999 Accord won't start on first attempt just clicks?!??!!?
I have a 1999 Honda Accord 4 cylinder. When I first hit the key it won't start it just clicks as if the battery is dead but there is power like normal. I turn the key back to the off position and hit the key again then it will start as if there is no issue. This does not happen every time, maybe 4 out 10 attempts. There are no check engine lights and everything (relays & fuel pump) seems to be working properly. Also, once started there are no driving issues. I first thought a bad battery connection and noticed the terminals/wires were corroded, so I replaced the wires/connectors and cleaned the terminals, still no luck.
Any other thoughts?
Old Aug 19, 2022 | 07:12 PM
Maxcapacity's Avatar
Default Re: HELP!!! 1999 Accord won't start on first attempt just clicks?!??!!?
Try cleaning the terminals on the starter and make sure they're on snug. The starter is not getting enough power.
Mr. Hamstar
Mar 25, 2022 09:46 AM
Katie Stanley
Aug 1, 2017 07:23 PM
eslerblake
Feb 21, 2015 08:00 AM
New Year Wishes
Oct 10, 2012 11:07 AM
Nessal
Jan 21, 2006 03:40 PM
