K24 swap no crank no start
Old Aug 15, 2022 | 01:33 PM
Wafflelawfulman's Avatar
Default K24 swap no crank no start
I've tried everything and have lurked everywhere so I'll lay out the issue. Here's my specs:00 civic hatch
k24a4
Kprov4Rsx harness
Hybrid conversion harness
Brand New main relayAem fuel pump
So none of these work as intended. Fuel pump and start work in testing but when turning the key neither of them turn on. At one point the fuel pump would turn on but would exactly prime as intended. It would run as long as I'd turn the key. Not just run for 3 seconds and turn off. Now it doesn't turn on at all. Bypassing the main relay it functions fine
Starter signal never would send out from the ecu in the first place. Wiring it directly to the battery it works fine.
At first I thought it was the main relay, I replaced that twice and it only clicks once. I measured continuity and the only one missing is the starter signal.
I can't get any of it to work. I have all the pieces needed and can't get it to crank let alone properly start.
Old Aug 16, 2022 | 09:21 PM
chidog's Avatar
Default Re: K24 swap no crank no start
Does the car have an immobilizer system ? If all wiring to and from ECU is good then it maybe an ECU problem. Having a nice scanner helps.
Old Sep 18, 2022 | 02:57 PM
Davidov22's Avatar
Can you confirm that the Starter has 12+V, hot at all times? Using a multi-meter.
Next you need to confirm that the Starter solenoid received the 12v start signal when the key is turned.
Old Sep 30, 2022 | 04:09 AM
No voltage at all on the starter solenoid and the security is shut off. Basically it's not using anything on the main relay correctly. Despite correct grounds and correct conversion harness
Old Jan 25, 2023 | 06:50 PM
joelfespinoza's Avatar
What happens when you turn the key on and jump the starter signal wire directly from the positive battery lead?
joexjoex44
11
Dec 10, 2009 09:17 PM
JDM Projects
Audio / Security / Video
Aug 26, 2009 04:52 PM
solk1dd
Jul 24, 2007 06:58 AM
angelinaspop
May 12, 2006 11:25 PM
