HELP B16A WONT START OR CRANK!!!!
i replaced the starter with a new one. fuse is good. fuel pump is giving fuel to the motor. and when i go to turn the key all i here is the fuel pump click on like its suppose to. but when i turn the key to try and crank it. nothing, not a sound. no spinning, nothing.
1 Post
Re: HELP B16A WONT START OR CRANK!!!!
Do you hear the relay click when you turn the key? If so, bridge the two poles on the starter solenoid with a screwdriver and then have someone else turn the key.
grounds are good. wires are good. heard of anything like some sort of kill switch? it makes no clicking sound. not one sound at all
Ive seen remanufactured starters not work.
Ive popped the 80 amp fuse before forgetting i didnt disconnect the battery.
Ive disconnected a cars battery with an alarm and had to find the little valet button
or switch so it will allow the car to be started.
