D-series shift linkage
Looking for a shift linkage kit for a 91 CRX Si, D-series engine. I replaced the bushings and shift lever seat but it's still sloppy. I don't want to spend $ on a used part on ebay and end up with the same problem. All I can find are linkages for B-series swaps. Is there an interchangeable part I could use ?
Unfortunately the only d series linkage you can use are from any 88-91 crx/civic. If you still have play at the joint up on the transmission, you can put a bolt in the hole instead of the roll pin. IF that is where your play still is.
Using a bolt is a dumb idea.. The spring pin is used for a reason.. there's nothing to compress with a bolt and it could cause the shift linkage connecting spring pin hole and trans shaft hole to obround and create more slop due to vibration from the engine.
OP just needs all new bushings in each swivel/pivot joint and should be set. There's plenty of videos and info out there on how to rebuild the original.
He has already stated that he replaced the bushings. And yea, the correct size bolt fits perfectly snug with zero play. It’s literally been in there for 15 years. Never going back to that dumb roll pin.
I bet the dual swivel joint bushings just before it meets the trans shaft are still his stock ones, need to cut the bushing shafts/pins heads off the links to replace those bushings and either tack weld them back on or replace with bolts. That joint creates alot of slop when worn.
The Tyrannosaur Tightener takes care of this problem. It is expensive at $130 but you'll never need to worry about the spring pin again and its B/D compatible - it worked great on both for me.
There is knockoff version floating around somewhere for half the price too I think, it should work just as well.
eHMxhACk
Dec 25, 2013 03:12 PM
CRX_RR
Mar 26, 2008 10:11 PM
