What the heck am I looking at!?
Old Aug 7, 2022 | 06:43 PM
gfEFbuildy's Avatar
Default What the heck am I looking at!?
Sorry I’m new to Hondas but what exactly am I looking at? I have a d15b block but I think I have a different head on it? maybe a y8? but there’s a machined hole on the intake side that pours oil out of it. I was just wondering what that’s for or what intake I should get to cover that so it doesn’t pour out oil. Any help is MUCH appreciated! Thanks guys.
Old Aug 7, 2022 | 09:24 PM
Tyson's Avatar
Default Re: What the heck am I looking at!?
That's the VTEC solenoid.
I'm pretty sure d15 VTEC exists. Not sure. Probably just Google it yourself.
Old Aug 8, 2022 | 03:35 AM
gfEFbuildy's Avatar
sorry that was a bad picture! I didn’t know I had vtec so thank you for that. That could probably use a new gasket at some point but right now I’m trying to figure out the hole on my intake side. It’s machined out and the IM and gasket only cover half the hole.
Old Aug 8, 2022 | 04:48 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Circle the hole that you’re talking about.
Old Aug 8, 2022 | 04:58 AM
gfEFbuildy's Avatar
Intake manifold scoops down showing the machined hole
Old Aug 8, 2022 | 10:13 AM
gfEFbuildy's Avatar
I loosened off the IM so it’s easier to see.. I have a machined hole that isn’t covered by the manifold. Do I just have the wrong year IM for the head I have?
Old Aug 8, 2022 | 11:42 AM
Maxcapacity's Avatar
Look at the front face of the head above the exhaust manifold, there will be embossed numbers and letters. Look for the code that starts as P** Those 3 characters will tell you what head you have, also in a different spot, there will be the year of manufacturing using its last 2 digits in a little dial form.
I noticed one of the studs has been replaced with a bolt that looked loose, unless you loosened it prior to the nuts in your pic, make sure it's not too long and bottoming out before it seats tight.
The head you have, is it a 96-98 or 99/00? The newer ones had air injection I think and the manifold has holes inside along its mounting flange, 1 hole above each runner port and a larger hole in the center where the line would connect on top of the flange itself.
People would plug off each hole in the flange and run the engine without the system for certain swaps or just deleting it. If there's a hole in the side of the head, plug it since your not using it. Look around at Google images for 96-98 vs 99-00 d16y8 intake manifolds and you will see. There's plenty of info about it out there
Old Aug 9, 2022 | 05:52 AM
gfEFbuildy's Avatar
Thank you! I have a z6 head. 94 P08-5. I just have a crazy oil leak and the hole filled up lol. It’s probably a good idea to plug it. Does anyone know what that hole is for?
Old Aug 9, 2022 | 06:33 AM
DaX's Avatar
DaX
Loved
Community Favorite
That's just how the head is cast - it's not a machined hole. There is hex-head a galley plug in that area...not sure if it's for oil or coolant though...if oil, it could be leaking from there? I'd be more suspicious of a leaky valve cover gasket and the oil running there and pooling, though.
Here's the intake side of my D16Z6 head - you can kind of see the galley plug I'm talking about.
Old Aug 9, 2022 | 10:58 AM
I was a bit confused as to what was going on. Was kinda thinking you just got the car and the motor was actually leaking from that spot and guessing maybe someone had removed the plug. Most likely it just pooled oil there like DaX said. Just need a new valve cover gasket!
TurboD206
Feb 20, 2011 05:50 AM
jrdnwheeler
Sep 3, 2008 08:48 AM
Corey_sl
18
Apr 6, 2008 06:56 AM
thomas188
Oct 7, 2006 05:28 PM
egizzle8
May 25, 2005 07:39 PM
