Making D15b2 with D16Z5
Old Aug 5, 2022 | 12:11 PM
Vasilije02's Avatar
Default Making D15b2 with D16Z5
I have D15B2 that make 90hp and use lots of fuel becuse of faulty carburator. I have D16Z5(basically D16A9), so i would like to know if a can use block from b2 and everything else from Z5, or use head, intake and cpu from z5? Help please
Old Aug 6, 2022 | 08:59 AM
jlicrx's Avatar
Default Re: Making D15b2 with D16Z5
do you have the complete Z5? if so, it would be a lot easier to just convert your D15B2 engine wiring harness to MPFI and swap in the complete Z5, along with the Z5 ECU, which would be a direct bolt-in to your chassis - the DOHC Z5 head is not a direct bolt on to the D15B2 block (bolt hole don't match, different size head bolts,etc.) - putting it on the B2 block could be done with a lot of work, (including machining), and a myriad of other changes - you would end up with a compression ratio of around 8:1 which wouldn't be ideal, plus you would still need to convert the D15B2 wiring harness to MPFI
PissedoffHONDA
May 23, 2008 08:21 AM
ej1252
Dec 11, 2007 03:11 PM
I got a honda
Aug 21, 2005 06:22 PM
