Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Ream camshaft not TDC (Timing belt pilot 2014 question)
Old Aug 3, 2022 | 10:31 PM
Marvs's Avatar
Default Ream camshaft not TDC (Timing belt pilot 2014 question)
Hello honda-tech peeps! I am almost 60% done with my 2014 pilot timing belt service. I already installed a new timing belt and made sure the crank bolt and both camshafts are TDC. But then I realized that the new tensioner can't be bolted in with the new timing belt installed. I unbolted the tensioner pulley to remove the belt. Front cam and crank bolt are still tdc but NOT the rear cam. The rear cam's reference mark is now at (around) 2 o'clock position. My questions is, how can I align back the rear cam to TDC? Thank you guys for any tech help👍🏼
Old Aug 4, 2022 | 05:15 AM
Ryanthegreat1's Avatar
Default Re: Ream camshaft not TDC (Timing belt pilot 2014 question)
Rotate it back to where it needs to be. Bolt on the end of the cam is safe for rotation.
Old Aug 4, 2022 | 11:22 AM
Marvs's Avatar
Thank you !
dleccord
Apr 13, 2020 08:03 AM
age_texas
Jun 4, 2012 07:20 AM
zueke
Nov 28, 2003 08:38 PM
eddiecut
Jun 16, 2003 12:10 PM
Comptech98GSR
Oct 30, 2001 08:06 PM
