94 civic ex something strange
Old Jul 25, 2022 | 04:15 PM
ecmhunter2000's Avatar
Default 94 civic ex something strange
So when i start my car it sounds like there is a rod knock but i did all the diagnostic tests and ruled it out but when i did a leak down test all my cylinders go to tdc when the timing marks are correct except no 2 with the marks where they are supposed to be it doesnt go to tdc has anyone experienced this
Old Jul 25, 2022 | 09:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 94 civic ex something strange
If the number 2 piston doesn't come all of the way up when the crankshaft is turned 180' from TDC, it is likely that you have a bent connecting rod... and a bent connecting rod will likely make contact with the saddle area of the block (bottom of the bore) and creating the "Knock" sound that you are hearing. Is your compression low in the #2 hole ?
Old Jul 26, 2022 | 12:12 PM
I haven’t checked it because I don’t have a compression checker but I tried to do a leak down test and it had a very slow leak plus I did the whole push down on the piston when it’s at tdc to see if I had a bad bearing and the bearings seem ok now can I replace that one connecting rod bu dropping the pan and pulling it from the botttom
Old Jul 26, 2022 | 01:53 PM
Ryanthegreat1's Avatar
Piston and rod go out the top. Have to remove the head.
Could drop the pan and see what is going on in there.
glynda russell
Sep 27, 2016 11:01 AM
y2kferari
Feb 10, 2010 07:38 PM
variablevalve
Feb 27, 2004 07:27 PM
