F22A6 to F22B1 swap: EGR help
Original engine bit the dust, swapping in a new economy engine. My egr didn't work before, I tested the system a while ago and I'm pretty sure it was the control solenoid in the vacuum box. Now that I have a fresh engine I'd like to get the EGR system working again. I can't seem to find a new control solenoid for sale anywhere, and the '94 solenoid(two wire) is different than the '93(three wire). I'm using the correct ecu for the engine. Should I buy a used solenoid off of ebay and hope it lasts, or can a '94 one be made to work? I don't need to pass emissions, so if the ecu knows the egr system isn't working will it compensate for it and run fine otherwise? What is my best option here?
Spade
Dec 13, 2001 08:11 AM
