Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Fuel pump ground location??
Old Jul 8, 2022 | 01:29 PM
James Roark's Avatar
Default Fuel pump ground location??
Can someone tell me where the fuel pump grounds to on the body/frame on my 7th gen civic? I saw an 8th gen video and it was under the driver's seat but I was just trying to find out if it was somewhere different before I start looking...
Old Jul 8, 2022 | 01:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Fuel pump ground location??
It is under the passenger seat.
Old Jul 8, 2022 | 01:36 PM
Thank you very much! And also for the quick response thank you!
Old Jul 8, 2022 | 01:37 PM
Oh is it under the carpet?
Old Jul 8, 2022 | 01:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
It is under the carpet.
Old Jul 18, 2022 | 05:19 PM
Thank you again, my ground location under the passenger seat was pristine, I ended up finding a broken ground wire in my fuel pump housing coming from the "fuel injector pressure regulator" and that was the problem. Car is running fine now but for some reason my cruise control stopped working after this, I had bought a new fuel pump, (pump only I used my original housing) because I thought it was the original problem, so I just left the replacement pump in place and fixed my broken ground wire and off I went. I've checked my fuses and connections at the throttle body but everything seems ok... any suggestions would be helpful thanks
cueto
Jun 15, 2009 07:37 AM
SilverPanda
Oct 3, 2007 01:56 PM
hipity_hopity_mt
Dec 27, 2006 02:16 PM
delguiner
Sep 7, 2006 09:31 AM
wumba
Apr 7, 2005 10:08 PM
