No Spark, turn over only
Old Jul 8, 2022 | 10:42 AM
YellowVtec's Avatar
Icon5 No Spark, turn over only
Niagara crx meet is next week, drive the car one mile, brought it back in the garage, changed the drivers motor mount and the side trans mount. Wont start back up... B18c1 p28 obd1 distrib
Check grounds, check coil, check rotor cap, all good from what I can tell. Car ran fine before. It has an alarm, wondering if that might be the isuse, it seems to disarm fine so maybe not. I have fuel pressure too.
I don't know what else to check, signal from ECU? Signal to the distrib? Running out of ideas and patients.
Any help would be appreciated.
Old Jul 8, 2022 | 11:13 AM
kraquepype's Avatar
10 Year Member
Default Re: No Spark, turn over only
If the coil checked out, the ICM in the distributor may have gone out. Have you confirmed spark?
Maybe also check the MAP sensor connection. Best of luck!
Old Jul 8, 2022 | 01:41 PM
YellowVtec's Avatar
Update im getting s code 15 on the p28 it's an ignition out put code. Make sense.
Old Jul 8, 2022 | 01:43 PM
YellowVtec's Avatar
Update im getting s code 15 on the p28 it's an ignition out put code. Make sense. Now to start checking into that.
Old Jul 8, 2022 | 05:07 PM
YellowVtec's Avatar
Found a broken black and yellow wire for the small plug on the distributor side in my obd1 to obd0 conversion harness, pain to fine but just kept digging.
turbocivic0618
Nov 13, 2005 02:42 PM
89dxhunchback
Nov 14, 2004 06:04 AM
95gsrturbo
Mar 27, 2004 12:15 AM
95gsrturbo
Mar 26, 2004 08:44 AM
Vanilla4215
Jul 10, 2002 10:37 PM
